2 hours ago, gr5 said:You probably already know this but "top" in cura has a specific meaning. If you are printing a cube then it matches the normal definition: the top layer is all top skin. But if you have say a pyramid then *every* layer has some top skin out near the edges of the pyramid. A sphere has a ring of top skin on every layer of the top half of the sphere and a ring of bottom skin on every layer of the bottom half of the sphere.
Yes, good point, but in this particular case, my "inner" layers are truely that except for 1, and its this layer that I'd like to be extruded normally and not with the skin setting. So I ended up merging 2 files worth of gcode. The code for no skin as the base of the file and then the last 2 layers from the file with the skin. Works almost flawlessly except for a tiny blob at the layer start which I think can be attributed to the relative vs absolute mentioned in the other comment. A little tweak and it'll be perfect.
--Scott
gr5 1,967
The "E" value is an absolute position - not relative position. "E1187.42799" means you have extruded 1.187428 meters of filament since you started the print (actually after so many meters it resets back to 0 as Marlin can't handle numbers over some value).
So just like X100 means X is at 100mm, E100 means the extruder is at 100mm. It's a position. Not an amount to extrude (which would be a relative value).
So just looking at one E value doesn't help you much. You have to subtract 2 E values.
gr5 1,967
sg000 0
Thats a huge help! I hadn't taken that into consideration. Thank you so much!
