Posted
· Custom Supports not working in small area
After some more tinkering, I figured it out. In order to have custom supports to be placed on the model (as well as on the build plate) I had to have the support setting set to Everywhere. The missing supports showed up after this.
In the end, this didn't produce the desired result as I didn't want supports inside the model. So I ended up enabling supports "Everywhere" and then using the support blocker instead to prevent supports inside the model.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
nospoon99 0
Hope this helps someone else.
