tinkergnome 929
On 3/16/2020 at 6:10 PM, CCA1 said:It is an Ultimaker 2 Extended Plus. Cura 4.5
Your pictures do not look like the printer definition of an Ultimaker 2+. It looks more like a Mark2, but with an incorrect start script. Was this per mistake or is it somehow intended?
I would add an "Ultimaker 2 Extended+" afresh to have a good starting point again.
Or - if the printer is indeed a Mark2 conversion: you could add a new "Foehnsturm Mark2", adjust the z-height or compare/repair the start script.
CCA1 15
Here is an image of one of my G- codes. It appears as though it might be having one too many retracts??? Is there a way to fix this????
