Install Ultimaker_Cura-4.5.0.AppImage
Michel_Goujon
Posted · Install Ultimaker_Cura-4.5.0.AppImage
Hello,
new comer to 3D printing and Cura ...
I'm running a Dell Vostro 1220 with SSD and Ubuntu 16-04.
I downloaded "Ultimaker_Cura-4.5.0.AppImage" from ultimaker cura web site and ... I do not know how to install this software !
Sorry, I'm also new comer to Ubuntu and Linux shell ... this may be the reason !
Any how thanks to the one who knows and agree to spend some time in helping me !
Michel Goujon
goujon.michel@cegetel.net
    Hi, you don't need to install it as such, you only need to make it executable. To do that on the command line do
    cd DIR_WHERE_FILE_IS_LOCATED
    chmod +x Ultimaker_Cura-4.5.0.AppImage
    You can probably also do it from your filemanager (perhaps, right click, properties?)
    Once the file is executable you an either execute it from the command line or from the file manager.
    Hope this helps!
    • 4 years later...
    HI
    I have an Acer Chromebook and I need to connect to my 3D printer. How can I use this same software to be compatible with the 3D printer?
    Thanks for the information.
