6 hours ago, ahoeben said:The model is probably non-manifold/“broken”. It needs to be repaired before it can be properly printed. Cura has an “Xray view”, hidden away on the Preview tab, which could show you (in red) where the problem is.
OK thank you
is the problem in Cura slicer or is the problem in fusion 360 were i created the obj file to export
Thank you
ahoeben 1,986
