Hi
I have a problem with top layer not being totaly filled.
I have redused the acceleration settings in Marlin to 1000 ( from 3000) and that helped a bit, but still not good. The filament is squized out to about 0.9mm, but there is stil a gap of about 0.4 mm between each tread.
The perimeters and loops is perfect, so I dont think that I suffer from under extrution.
It looks like the hotend moves to fare from the previous tread....
This is my settings:
https://dl.dropboxusercontent.com/u/55953222/Settings.JPG
Johan
    Please post a picture of the ".4mm gaps".
    This could be caused by many things. The most likely is something called backlash which has the tell-tale pattern of every other line is touching, and then a gap (touching/gap/touching/gap repeats across the top). There are many things that cause backlash - the easiest to check is belt tension - usually short belts:
    Here is a photo showing backlash and how it was fixed:
    http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/?p=14396
    The very next post explains what causes the pattern.
    Thought I had my shortbelts nice and tight, but....
    I have covered the printer with a large plastic sheet, to create a heated champer, so I guess the wood have dried out and loosened the bolts for the steppers.
    I will run a new print tomorrow to se if the problem is solved, but I really think you nailed it!
    Thank you!
    Johan
