If you want to experiment - copy the marked line from the Ultimaker2 to the "Mark2"- json-file and define your own list. Essentially: overwrite the list with a shorter (or even empty?) list.
tinkergnome 927
The technical reason is easy:
The Mark2 definition inherits from the regular Ultimaker2 plus definition - and Ultimaker has a whole bunch of materials excluded for the latter. See:
https://github.com/Ultimaker/Cura/blob/master/resources/definitions/ultimaker2_plus.def.json#L16
