I have a UM2.
I really want to print with the wood filament, but it looks like I'll need a .8mm nozzle.
I have an extra nozzle to drill out. But how do I switch out the existing nozzle for the new one?
This would be handy for maintenance in general...to know how to replace this part.
Another option before replace.
http://colorfabb.com/woodfill/6-woodfill-fine-300.html
also i think this must work too.
iam so interesting in print with wood filament as well but not in change nozzle usualy.
Daid 306
You'll have to remove the 4 screws on the side that hold the fans. Then heat up the hotend. Finally rotate the "ring with holes" to push out the hot hotend. You can rotate this by using the screw-driver as lever.
When inserting the new nozzle, make sure the teflon piece is pushed up, as the teflon needs to make a perfect contact area with the nozzle pipe, or else you'll get plugs.
The nozzle and heater-block are 1 part on the UM2. The nozzle that is sold in the shop is for the UM-Original.
