Can my product be printed without supports?
Posted (edited) · Can my product be printed without supports?
I have never 3D printed before.
I have created a product which i hope to 3D print.
It contains overhangs(those blade like structures in the middle) and i want to ask whether it can be printed without supports or not.
If not, then i would like to know how will i be able to remove the supports as the size of my product is very small and without any gaps.
207402326_Screenshot(31).thumb.png.e8960b5a82cb881366e52b1b2ac76fae.png1951761896_Screenshot(30).thumb.png.65e55d9949e0b219f1465c76cd50f6d9.png1054854650_Screenshot(29).thumb.png.b61e903dcce6e779dccba9052b05f014.png24210759_Screenshot(27).thumb.png.36cc64333b3d45b7c5d2b3d8fd2ee38a.png
The images i have attached here are with different number of blades i.e. 4, 3 and 2.
I have also included a sectional view.
I want to know whether printing with different number of blades(with or without supports) will be possible or not.
The thickness of the blade is 0.5mm.
I would have tried it out but i dont have access to a printer currently, i will have to pay to use a printer so i just want to be sure.
Any help will be appreciated!
Thanks
Edited by swish_31
Incorrect orientation of images
    Posted · Can my product be printed without supports?
    At this type of scale you're not going to be able to do it with an FDM printer like an Ultimaker. You're going to need to go with an SLA printer or something similar. But yes, with the right type of printer you'll be able to print this.
    • Thanks 1
    Thanks for the answer sir.
    i wanted to know, as in SLA printing there are generally lots of support structures, how will i be able to remove those from under the blades as my entire product is really extremely small.
    Will this product be possible in SLA without supports?
    I am attaching my STL file for your reference.
    Another thing, also is there no possibility of this being printed on a FDM printer.Main body MK4.stl
    Thanks
    Technically you could probably print this using FDM if you used a smaller nozzle such as 0.25. But I'm guessing the surface quality is quite important on these so SLA might be a better bet. If I were to print it using SLA I would try printing it straight on the platform without supports. It's not the way it "should" be done, but I think it could work.
    If you do it correctly and tilt the model and add supports I think there's a good chance you could damage the blades when removing the supports since they are so thin.
    Also, I think you need to fix your model because the blades are not attached to the walls.
    • Thanks 1
    If you have access to dual extrusion you could try printing the support with PVA, and dissolve it in water once the print has finished. It might still leave a rough surface finish on the blades.
    To get the blades as smooth as possible I would suggest using a variable layer hight. This setting is called 'Use Adaptive Layers' in Cura 4.5 and can be found in the 'Experimental' settings.
    • Thanks 1
        This update is for...
        All UltiMaker S series
        New features
