Multi material with a single extruder? I think this only works with a special setup as the Prusa MMS or the Palette. But that's totally out of my knowledge.
Regards
Regards
Ok thanks for your time. I thought it was possible to print on top of an other print.
Ok, I understand. I misunderstood your question. If it' just one object on top of another (and another object ontop...) and each objects has an unique material and colour, you could try to do it "manually" by stacking the objects in Cura and manually change the filament, using post processing scripts (for example "pause at hight" or "change at hight").
Could you not "PAUSE" the printer after curve has completed, remove the material, then insert different colour? Making sure you "FOOL" the printer into thinking, it's the SAME material by choosing the material manually and not via NFC tag?
Edited by CarbonOn a single-nozzle printer, another option might be to cut out the drawing from the base, all the way down to the bottom. So you have two separte models: the base, and the drawing. Print both in separate jobs. And assemble and glue both together. You will need to add quite a bit of tolerances, test, and post-process each part, to get the thin parts into the base. And it won't look very smooth probably. But it should be doable.
Enigma_M4 120
Hi Multiholle,
I fear your project is only possible with a dual (or multi) extrusion printer, because fdm printing works building layer-by-layer. Printing on top of curved surfaces is (actually yet) impossible.
But: your design is exactly what you need to make a dual material print (in Cura: load both files, merge files and connect each file with another extruder).Cura print guide - Printing with two colors.pdf
Regards
Edited by Enigma_M4Cura print guide
WouterFonteyne 0
Hi Enigma_M4 how can i print two parts on top of each other in different colors with only 1 extruder? The object are flat by the way. I have the same question as Multiholle but mine are flat surfaces.
