No regulation of the LED strip / UM2+
urel
Posted · No regulation of the LED strip / UM2+
Hello,
with my Ultimaker 2+ I can neither switch the LED band on nor dim so I cannot adjust anything. It is only switched on at 100%. Since I have been using Simplify3D, I have not been able to adjust the brightness. Previously, I was advised that the printer settings would be overwritten.
Can someone help me who has experienced the same thing?
    And I thought the first answers were coming ...
    Disappointing - just as I am from this printer. I have 8 Printer and in contrast to this, the others make me happy.
    regards
    urel
    This is a forum of volunteers, they are not getting paid to answer you within a certain time frame.
    If you are unable to change the brightness of the LEDs from the menu on your printer then it's possible that the component that drives the LEDs has broken and is therefore giving the LEDs full power regardless of the setting.
        • 4 replies
