fbrc8-erin 316
It should definitely be doable. With the S5, that back piece of plastic lifts straight up on off instead of backwards as in my video.
1
14 hours ago, fbrc8-erin said:It should definitely be doable. With the S5, that back piece of plastic lifts straight up on off instead of backwards as in my video.
ok, thanks
Enigma_M4 125
although I was not forced to change the print head bearings yet, a good tutorial for disassembling and reassembling the print head can be found on youtube, provided by @fbrc8-erin:
https://www.youtube.com/watch?v=Qf-X8F_9zg0&list=UURBgc5zvVEBMU9o7YjCzFYA&index=2
and here's a good source for small repairs of all kind:
https://ultimakernasupport.zendesk.com/hc/en-us
Regards
fbrc8-erin 316
The process is definitely very similar between the two models. The biggest difference is going to be that your printhead cable clips into the back of your PCB on the S5/S3, but on the front of the PCB on the UM3/UM3X.
Edited by fbrc8-erinAlso, depending on the age of your UM3/UM3X, the back piece of the cover may lift off backwards instead of up as it does on the S5/S3/later UM3/UM3X.
Link 35
Thanks, I have a S5, but sounds like it shouldn't be an issue to do myself?
