Ultimaker 3/S5 print head bearing replacement
Link
Posted · Ultimaker 3/S5 print head bearing replacement
has anyone changed the print head bearings on the 3 or the S5 (assuming the process would be the same), how difficult was it ?, any guides ?
Thanks
    although I was not forced to change the print head bearings yet, a good tutorial for disassembling and reassembling the print head can be found on youtube, provided by @fbrc8-erin:
    https://www.youtube.com/watch?v=Qf-X8F_9zg0&list=UURBgc5zvVEBMU9o7YjCzFYA&index=2
    and here's a good source for small repairs of all kind:
    https://ultimakernasupport.zendesk.com/hc/en-us
    Regards
    Posted (edited) · Ultimaker 3/S5 print head bearing replacement
    The process is definitely very similar between the two models. The biggest difference is going to be that your printhead cable clips into the back of your PCB on the S5/S3, but on the front of the PCB on the UM3/UM3X.
    Also, depending on the age of your UM3/UM3X, the back piece of the cover may lift off backwards instead of up as it does on the S5/S3/later UM3/UM3X.
    Edited by fbrc8-erin
    Thanks, I have a S5, but sounds like it shouldn't be an issue to do myself?
    14 hours ago, fbrc8-erin said:
    It should definitely be doable. With the S5, that back piece of plastic lifts straight up on off instead of backwards as in my video.
    ok, thanks
