Machine Settings Dialog not resizable under MacOS?
MisterPi
Posted · Machine Settings Dialog not resizable under MacOS?
I have searched a while to see if anyone else has reported this, to no avail (guaranteed not an exhaustive search).
I have two printers installed (and working) under Cura 4.5 running on MacOS 10.13.6 (High Sierra).
In neither case are the machine settings resizable, making it very difficult to edit before & after gcode.
Am I missing something or is it just me?
Thanks.
    Have a similar issue on PC, the screen is re sizable but sometimes the text shows up blank or overlapping.   If is shows up blank or overlapping the only solution is the re size the window as big as possible and eventually all the text is visible.
