Posted (edited) · Several issues in 4,5.0 Win 7 64bit
Hi all,
I hope you are all well...
I am using a laptop, no separate keyboard or mouse...
In the rotation, I can only rotate on the red axis & not the green or blue axis
In the preview after slicing, there is no option to play the simulator, whereas it should be at the bottom-middle of the screen...
If I import a model that was designed larger than the settings for the printer bed to use, it will not let me resize or rotate to angle it across the corners to fit...
Can you please advise if any settings need to be changed or if I need to do something in particular to get this software to work as should...
Thank you in advance, for your valuable time to help out...
Edited by Welsh-Dragon
