So you are saying because it is 3 line widths instead of 4, that is the issue?
Do you know the GitHub issue number, so I can track progress?
12 minutes ago, ChaosBlades said:So you are saying because it is 3 line widths instead of 4, that is the issue?
Yes.
13 minutes ago, ChaosBlades said:Do you know the GitHub issue number, so I can track progress?
AFAIK, there isn't an issue on github specifically about this.
The PR that could form the basis of the solution is https://github.com/Ultimaker/CuraEngine/pull/1210
You can see from the comments there that it still has some way to go before becoming a reality.
In the situation I am talking about the wall thickness is 1.2 mm, the line width is set to 0.4 mm, and the number of lines is 3. So the line width should not vary, it should stay at 0.4 mm.
If the perfect world what I just said above would be true but thinking about it, I think it does need to vary the line width due to the nature of the STL and how circles are not perfectly round and some places are going to be slightly thinner than others.
In Prusa Slicer I can see it can vary the line width when filling out gaps between walls. I can also see some lines from my above pictures are no longer printed when I disable fill gaps between walls.
Edit: Setting Line width to 0.39 mm also 'fix' the issue.
Edited by ChaosBlades
burtoogle 508
This is all known behaviour for Cura. It cannot at this time make a good job of walls that are not close to an even number of line widths wide. I believe that the Cura devs are addressing this long standing deficiency.
