I am using an Anet a8 I just purchased. The software is cura 4.5.0. Im having trouble changing the x y x in the print settings and im thinking that may be the issue. The settings aren't letting me change the default settings as instructed in other videos I've seen.
gr5 1,870
One of your axes is slipping. I can't tell if it's the X axis (left to right) or the Y axis (front to back) but it's the axis that goes left/right in the lower picture.
This is usually caused by loose set screws on pulleys - those have to be tightened to the extreme. Something is slipping somewhere in your hardware. Ask other people who own the same type of printer as you do (what type of printer is that?)
