what is a "quality profiles" I dont see quality profiles anywhere in Cura do you mean default and custom print setting profiles?
and can you explain how the settings either material, print profiles or advanced settings end up on the printer? is it in the Gcode regardless of which Gcode flavor??
thanks
ahoeben 1,968
Cura has different "layers" of profiles that get applied in a specific order. Each setting can have a value in each of these layers. So for example you can set a printing temperature for the machine, for the material, for quality profiles and a value in the advanced settings list. If a value is set in the quality profile, it will overrule what is set in the material. If a value is set in the advanced settings list, it overrules what is set in the quality profile.
