1 hour ago, Torgeir said:Hi Wels-Dragon,
You actually have the best slicer!
There is no simulator start button for Cura, but there is a drag down ball that you can use to see your sliced model layer by layer.
I've put this text on your attached picture.
You can drag the ball marker
down and see all sliced layers on by one.
Alternately, just select any number between
0 and 99 in the layer view window on top of the pole.
Here is your picture:
Hope this helps.
Thanks
Torgeir.
Thank you for your prompt reply @Torgeir, I really appreciate it...
The folks & Ultimaker with Cura on Youtube certainly have the Print-Simulator as can be seen in Cura 4.5 beta release today! join the bug hunt before the official release & on Ultimakers own youtube channel, Ultimaker: How to use the layer view in Ultimaker Cura,
Mentioned on Github as an incompatibility with the graphics driver of this laptop, which means if there is no updated drivers or any updated drivers still not compatible, I will not have the Simulator on the machine...
Torgeir 146
Hi Wels-Dragon,
Hope this helps.
Thanks
Torgeir.
