Just used this with some modification - it was still a bit small on my monitor. Helped a lot. But, the menu bar text on Windows 10 with a hi-res monitor is still very small. Are there any theme settings for the menu font? I couldn't find one.
The menu should use the system-defined font and size.
ahoeben 1,601
Cura is fairly well themeable.
Download this file: https://gist.github.com/fieldOfView/7de3ad07fa06afb821bc0c5fe0b668dc
Put it in ~./config/cura/4.5/themes/larger-text/theme.json
Restart Cura
In the general preferences, select the theme Ultimaker Larger
Restart Cura again
