Thanks for the answer,
At first i see i have write something wrong in my system description.
I use cura 13.11 not cupcake 13.11.
Thanks for the recommendation to test the "Machine center 0,0" I think it is not activated, i will check if i m back to my living room.
Did someone know how to setup gpx for converting gcode to x3g as postprocess in cura - it can be used as plugin but i did'nt know how to setup cura.....
The machine connection - i think connection should work as minimum.
Today i read a little bit mor about gcode and x3g.... at this time i know x3g is not an expansion of classic gcode...
so if my machine spoke x3g and it get a gcode "hello"comand it would not answer.....
gr5 2,210
Which version of Cura?
In cura 13.11 go to "machine settings". I think maybe you have to check the box next to "Machine center 0,0". I think this might fix this:
I don't know if Cura knows how to print the x3g format - I doubt it. I would stick to replicatorG for the final printing step after converting to x3g. The way Cura detects the baudrate and the way Cura detects if there is a printer is by sending a gcode and waiting for the response. So this will not work with an x3g format printer.
So you should use cura *only* to slice and create the gcodes. Then convert to x3g (binary format). Then print with replicatorG.
