tinkergnome 927
3 hours ago, MagicalBeard said:if I check "print bed cleared" then it will automatically start the next print.
The only way that i know is to set the printer status to "not available" on the Ultimaker Connect page (web browser). There's a 'Manage printer' link on the 'Monitor' stage in Cura. It can't be done from the printers menu.
While the printer is "not available" you can do any necessary maintenance tasks, material changes and such things.
Set it back to "available" and it will continue to process the printing queue.
1
1
Erifor 0
Only way I know of is by using Ultimaker filament and selecting different colors for different jobs in Cura. However there's most likely some override I'm not aware of.
