Thanks for the quick reply, Torgeir...yes, I indeed have the UMO+ with PT100 sensors. I used the word "thermocouple" generically, and incorrectly.
I have a digital high temp thermometer which uses a K thermocouple sensor. When my bed is set at 70C, the external thermometer reads 62 degrees. When I put the probe against the outside of the heater block, it reads 235C when the UMO+ readout is 220C. My UMO+ was purchased in the summer of 2018. I did replace the heater block PT100 sensor about a year ago, but I never changed the bed temp sensor.
On a separate, but perhaps related issue, is there a firmware upgrade that might be necessary, or advised?
Thanks for your help
Bob
Torgeir 205
Hi bobrieg,
Welcome in here.
If you have an UMO+, you should not have thermocouples, right?
Normally this setup is using PT100 a very accurate temperature sensor and do not require any calibration.
Please confirm.
Thanks
Torgeir
