Control Panel Jog Controls in RepG 26
almi
Posted · Control Panel Jog Controls in RepG 26
Hi all,
I have installed RepG latest version 26 for Windows XP, and in the Control Panel want to adjust the Jog Controls in Jog Mode below 1mm, for example 0.5mm.
But the axis won't drive, no matter if x,y or z !!
Does anybody have a clue? Does this have anything to do with comma separation '.' and ',' ??
By the way, I am also missing kind of a STOP function in this panel. Is there a new version out yet?
Thanks for any support!
Kind regards,
Andreas
    I don't understand.. Do you mean that you see the setting to jog at 0.5mm but it doesn't do anything or that you don't see it at all? Did you download repg from the ultimaker site?
    edit: if you want, you can do File->Preferences menu, set the debugging level to ALL, try the jog again then set the debugging level back to whatever it was. Copy the text from the bottom of repg and paste it here..
    I also don't have one in the control panel. I think that's normal..
    Hi Dave,
    thanks for your response.
    I see the settings in jog mode going to 0.5mm, but the motor won't drive.
    It is the RepG version from the Ultimaker site.
    Here is my log file:
    [14] received: ok
    [14] Unable to retrieve updated position, using position received last.
    [14] sending: N737 T0 M105 *64
    [14] received: ok t:19.53, raw:40 b:0.00
    [14] sending: N738 M114 *11
    [14] received: x:0.00y:0.00z:-2.00e:0.00
    [14] received: ok
    [14] sending: N739 T0 M105 *78
    [14] sending: N740 M114 *4
    [14] received: ok
    [14] sending: N741 T0 M105 *65
    [14] received: ok t:20.02, raw:41 b:0.00
    [14] sending: N742 M114 *6
    [14] received: ok
    [14] sending: N743 T0 M105 *67
    [14] sending: N744 M114 *0
    [14] received: ok
    [14] sending: N745 T0 M105 *69
    [14] sending: N746 M114 *2
    [14] received: ok
    [14] sending: N747 T0 M105 *71
    [14] sending: N748 M114 *12
    [14] received: ok
    [14] sending: N749 T0 M105 *73
    [14] sending: N750 M114 *5
    [14] received: ok
    [14] sending: N751 T0 M105 *64
    [14] sending: N752 M114 *7
    [14] received: ok
    [14] sending: N753 T0 M105 *66
    [14] sending: N754 M114 *1
    [14] received: ok
    [14] sending: N755 T0 M105 *68
    [14] sending: N756 G1 F92 *97
    [14] received: ok
    [14] sending: N757 G1 X0 Y0 Z-2,5 F92 *29
    [14] received: ok
    [14] sending: N758 M114 *13
    [14] received: ok
    [14] sending: N759 T0 M105 *72
    [14] sending: N760 M114 *6
    [14] received: ok
    [14] sending: N761 T0 M105 *67
    [14] sending: N762 M114 *4
    [14] received: ok
    [14] sending: N763 T0 M105 *65
    [14] sending: N764 M114 *2
    [14] received: ok
    [14] sending: N765 T0 M105 *71
    [14] sending: N766 M114 *0
    [14] received: ok
    [14] sending: N767 T0 M105 *69
    [14] sending: N768 M114 *14
    [14] received: ok
    [14] sending: N769 T0 M105 *75
    [14] sending: N770 M114 *7
    [14] received: ok
    [14] sending: N771 T0 M105 *66
    Interesting.. It's probably tripping over using , instead of . as a decimal point.
    That would explain why moves over 1mm work but moves under 1mm don't. I'd bet good money that if you told it to move 1,99mm, it would move 1mm because the arduino sees , as a non-numeric character and stops reading.
    You can:
    A: ignore it - it's a control panel bug and gcode from slicers will work fine, or
    2: mess with your system so that it uses . as a decimal instead of ,
