I did not save the gcode unfortunately I just re-sliced to fix it. Guess that would have been helpful.
No plugins, just vanilla cura. Could be a display error but the preview actually drew the entire layer like that so I wasn't about to risk it.
I tried re-slicing a few times but I couldn't replicate the error.
I've attached the file and the gcode I ended up with after re-slicing, don't know if you can get anything from that.
gr5 2,224
Wow.
Did you save the gcode by any chance? If so, please post. I've never seen anyone mention this kind of thing before with Cura. Ever. Maybe it's just a display error.
Are you using any plugins? Like the pause-at-Z plugin? If you use a plugin for one part and then forget, and slice something else the next day, the old plugin is normally still there and still active.
If you have the gcode and the project hasn't changed then it would be great if you could post the gcode and also the project file.
