I checked and Acceleration and Jerk have almost no impact on print time. The difference between UPstudio and Cura is twice the time so I think it's a more complicated problem.
Does anyone knows what could happen ?
Jean
Jean
I ran a test by printing a 100x100x100 mm cube empty with 0,2mm and 50mm/s and Cura gives me a print time of 1,27hours wich is more like 40mm/s.
More of a problem, when I change print speed to 100 mm/s I still get 1h27minutes print time. Changing print speed had no impact on print time at all.
Does anyone know what is wrong?
Thanks !
Hover your mouse over the "i" in the lower right corner, that'll show you how much time different parts of the print is taking. That might give a clue.
Thanks for your help. Actually With the cube there is only walls with 1 layer and it shows a clear "bug" from Cura with this profile.
I don't know if it's possible to correct the profile to make it work good?
It seems that whatever the printspeed I add in Cura it will print at 40 mm/s
nallath 1,120
Probably because of different acceleration / jerk settings.
