Ok thanks, will take a look at that.
Other thing I note which is annoying, I don't seem to be getting any retract on skirt or first layer moves which means I get over extruded mess on moves leaving a poor finish.
Is this something that can be fixed?
gr5 2,194
This seems unlikely but possible. Are you sure you aren't getting MINTEMP or MAXTEMP errors? Is this a um1 or um2?
Search the gcode file for M104, M109. e.g. M104 S0 turns off the extruder heater.
This is a common problem. The models have extra internal walls or holes in the walls. Experiment with the 4 checkboxes in the "check horrible" section. It's easy to try all 11 combinations of checkboxes to see if you can fix this. If not you have to look at the model in "xray view" instead of slice view and fix any red areas. But usually "fix horrible" can take care of it.
