Since you are talking about swapping nozzles, I assume you have an olsson block. Did you configure your UM2 in Cura to have an olsson block? In that case there should be an easy dropdown to select nozzle sizes, and 0.8mm is one of them.
Ah, apparently this changed in Cura 4.4, and you now have to add a new printer with the definition "Ultimaker 2 with Olsson Block". Once you have added that, you can select the nozzle size in the "Select configuration" dropdown. Fairly well hidden.
ahoeben 1,981
neo-ninja 1
do yuo mind just screen grabbing a pic for me? I cant see in cura that being an option anymore.
In the old version i remember it but i cant see it in the new one.
Big thanks in advance!
