Posted · Cura 4.6 + Klipper stutters a lot
All settings are the same. It´s something else, the gcode file size of same model sliced with same settings/profiles are a bit bigger as well.
I guess 4.6 does something different. I´m not the only one with this issue, it seems very common actually. I´m fine running 4.5 instead. Just wanted to make a heads up to devs and anyone else wondering why their prints look like crap
    I should think that it is due to the regression in the polygon simplification that has caused other quality issues. I believe they are working on a fix. In the meantime you may wish to try one of my builds which does a lot of stuff differently to the UM builds and may produce better results (YMMV). My builds are available from https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0. Please read the README.md file there before using.
    On 4/29/2020 at 2:58 PM, jklsdjkhfljhkldfugsldiufgb said:
    Are you using Octoprint?
    If so, are you printing from 'virtual SD card'?
    Yep, I am printing from vSD
    The issue lies in 4.6 somehow
    I slice with another version now so problem is "solved"
    What version are you using now? Thanks
    4.5
    4.6.1 is out but I haven´t seen anything in the bugfix list that seems to adress this issue. I might be wrong but 4.5 works just fine for now
    6 minutes ago, dubbeltrubbel said:
    4.5
    Thanks, my Cura 4.6.1 has started to go really slow whenever I change settings, so I need to backup profiles and re-install.
    I think I'll go back to Cura 4.5 🙂
