After disconnect and connecting printhead cable, printer works again.
Thanks
1
Thanks
Hello all,
I have the same ER34 issue. Just wondering if opening the print head won't void the warranty as it is a new printer
Since we have the Ultimaker S3 we had the ER34 five times! It mostly likes to pup-up in the middle of a large print. So, you must disassemble the print-head and reassemble it. And not to mention your print is ruined. As much as I like the S3/S5 and some of their features, this is bad engineering! Ultimaker should design this better in this price range I think this is unacceptable!
SandervG 1,521
Hi @ganimagaan, thank you for your post. You could try to open up the top bracket of the print head, in it should be the print head cable connector. If you press it to make sure it is connected properly, does the error go away?
Here is a video that explains how:
