I'm not quite sure I understand the problem.
Could you elaborate what you mean by "I am only able to have one at a time in the manged printers list"?
Do you have multiple printers "added" to Cura?
Are all your OctoPrint instances listed in the "Connect to OctoPrint" dialog?
What version of Cura did you upgrade from? Did you keep your configuration between versions, or did you start over?
glennemay 0
I think I figured this out.
Instead of being able to add the printer directly with the Octoprint instance. I had to add the printer as a local printer, select it and then connect to OctoPrint.
A little cumbersome. But I believe I have it.
It would be GREAT if this were a little more intuitive.. Or I would love to know the reason behind it.
