Thanks - will give this a try.
That solved the problem - thank you very much.
Can you explain a bit further please why the problem occurred? I'm aware that there is a minimum width of line that can be printed, but thought it was related to the nozzle diameter (0.4mm in my case) and was keeping my walls (maybe that's the problem - lines vs walls) larger than that. In this case the inner and outer diameters of the cylinders were 0.5mm different which I thought would eliminate the problem.
Again many thanks in advance.
Alister.
ahoeben 1,654
You could turn on the "Print thin walls" setting. The cylindrical features are quite a bit thinner than the line width, so normally Cura will not put a line in their place.
