Not this much. Load the stl file and look at it.
Looks like your file has something wrong. I converted it in Solid and saved it as STL. Looks better now, isn't it?
Yes, that fixed it. How did you do this?
@wingo I imported your STL in my CAD software; stiched all the surfaces together that resulted in a manifold solid and then export a new STL file out of it.
I tried that using my cad software(dsm) but it did not work. What CAD software do you use?
@wingo I'm using Keycreator 2020 from Kubotek.
nallath 1,080
Correct. There is always some space taken up by build plate adhesion (and some travel moves, depending on your settings)
