[BUG] Cura CANNOT load relative extrusion files
thanhtacles
Posted · [BUG] Cura CANNOT load relative extrusion files
Here's the outer wall of a simple 20x20x1 square, if you slice it with relative extrusion.
You get these really thin lines, and travel lines, and that's about it. I don't understand it. It SHOULD look like the below figure.
This error does not happen when sliced with absolute extrusion checked
