If I edit the speeds in the sidebar, I get a popup notice every time I change the profile notifying me that the default was overwritten and if I wanted to keep or reset it to the default. That's why I was looking for a way to permanently set such basic values.
I guess the way via .def.json files is the better then because then others could also benefit from it. Could you point me to a suitable set of such files that can be used as a starting point for a new set? Or is there even a documentation on how to create (and contribute) such new printer definitions to Cura development?
ahoeben 1,968
You can edit the speeds in the sidebar. The "Custom FFF Printer" and the Machine Settings dialog only let you set a minimum number of settings for the printer.
If you want to make a printer definition that you can distribute to others, you would need to make a set of .def.json files, and those can also contain speeds.
