Hello!
Of course! And one thing... Slicing is fine, if i turn oject to another face down. Problem occurs only when this flat part is oriented horizontally.
At X-ray view there is no visual problems...
-Raimo
Hello!
-Raimo
This doesn't look right at all... 😲
A solid (watertight) model is needed for 3D-printing.
This one consists of 370 separate shells that are not connected to each other:
Similar issues for the other one:
There are online tutorials for many modelling software products that explain how to design proper models for 3D-printing.
Which program did you used to create these?
Hello!
Oh my god! I use Freecad and i Exported models by selecting everything with box selection... I followed generall tutorials, but have to miss some step to make model as whole... Thanx I examine this and try figure this out!
-Raimo
WOHOU!!!
That cracked the case! I made union form whole object before I exported STL file..
Thousands of thax!
peggyb 169
can you share the model to have a look?
did you check the model with the x-ray view?
