Thank you.
That's toooo bad, it could save so much plastic and time !
Is there another software that could do that ? Thanks
Thank you.
In experimental section, tick box labeled 'make overhang printable'
or play with the tree support option
Edited by obewan
"Make overhang printable" could be perfect if the slicer wouldn't print this part as a shell, because it does so it's not possible to remove this part afterwards.
I don't know how I could play with the tree option, do you have any ideas ?
Enigma_M4 98
Hi Feuille,
there was an attempt before:
https://community.ultimaker.com/files/file/2609-a-suggestion-for-a-new-support-type-i-call-it-ramifications
but I as far as I know it never was implemented.
Regards
