CustomSupportCylinder
Cuq
Posted (edited) · CustomSupportCylinder
Hello,
I'm working on a plugin based on the CustomSupport plugin. But in this case I'm not creating a cube but a cylinder.  I haven't any problem to get the right length ( from the picked point to the base) but I wanted to define the radius as a parameter in order to be able to customize this value.  Is it possible to add a customized value ? or to get an existing value for this parameter Ie : support_conical_min_width ?
Cylinder.zip
Edited by Cuq
change text
temporary solution : using the value of support_tower_diameter  (Support as Tower diameter) as Cylinder diameter:
        # get support_tower_diameter as cylinder value
        id_ex=0
        extrud = Application.getInstance().getGlobalContainerStack().extruderList
        DiamCylinder = extrud[id_ex].getProperty("support_tower_diameter", "value")
Edited by Cuq
    Posted · CustomSupportCylinder
    So my question is now where can I find a "basic sample code" or how to implement in this plugin a windows to define specific parameters to define the size of this cylinder ? Hereafter a sample view of the expected function to clarify my request.
    Step by Step thanks to the plugin ZOffset  I found  a solution to define a new parameter. Still looking to define this value via a dedicated windows
    29 minutes ago, ahoeben said:
    Why would you want this to be a setting though? Couldn't it just be a numeric input field in the tool panel?
    That's exactly what I want , using a setting is not the right solution but as I don't know how to implement such type of numeric field in the tool panel it was for me a workaround.   In the different plugins there is no sample code to integrate this type of function.  I'm just a beginner in Python coding and this type of code is too hight level for me without an existing example.
    Edited by Cuq
    Cura has many included plugins that you could use as an example. The translate tool has numeric input fields:
    https://github.com/Ultimaker/Uranium/tree/master/plugins/Tools/TranslateTool
    Ok it's a little bit more clear now, I can define this windows ..  But I still have some problems to understand how the Binding mecanism works between the windows and the main code. Can you help me on this point ?
    I have now a control TextField and  I can fix the value with the code :
        def getDiam(self) -> float:
            """ return: Diam  in mm.
            # get diameter_custom_support as cylinder value
            id_ex=0
            DiamCylinder = extrud[id_ex].getProperty("diameter_custom_support", "value")
            return DiamCylinder
    but how to get back this value form the TextField ?
    Edited by Cuq
    If you put the whole thing up on github, I can help you later this week.
    • Thanks 1
    thanks a lot ...
    It's working, but as I m a newbie in Python it's absolutly not
     a clean code.. So yes  if you can have a look and clean it a little bit or give me some advice it would be very nice :
    The plugin source code on Github
    Ok I will try to modify my present code according to your recommendation.
    Thanks a lot for your time and the support you give us
    Ok I think I have  simplify the source code and based on your recommendation switched to the solution of storing the support size value in Preference "customsupportcylinder/s_size"
    CustomSupportCylinder on Github
    Edited by Cuq
    Cool. Don't give too much credit to lokster; his plugin is 98% my work on the Support Blocker. What you are doing is already much more interesting.
    Ok
    I wasn't aware about, that.
    Thanks to your help the plugin is now "acceptable". So next step for me: find the solution to create a curapackage. Can you point me to a tuto or document which explain how to do that ?
    [Edit]  your solution in test https://community.ultimaker.com/topic/26046-writing-a-custom-cura-package/?do=findComment&comment=229467
    and https://github.com/Ultimaker/Cura/wiki/Creating-Packages
    But my goal at the end is not necessary to put it on market place. Is it possible just to get the curapackage via this solution ?
    Edited by Cuq
    Yes. You upload a zip containing the source of your plugin, and before you submit it for approval, you can download a curapackage.
    Finaly I don't need to go throug the market place. I made the file "manualy" it's working for a basic install on my Cura release 🙂
    CustomSupportsCylinder1.0.0-sdk7.0.0.curapackage.zip
    I think I can understand now your remark 🙂  he seem's to be the king of copy/past  except for the section "Donate to the plugin developer!" this part of the source code is definitly his own 🤣
    Edited by Cuq
