31 minutes ago, burtoogle said:
Thanks Burtoogle! Am I right that to install the plugin I just need to copy folder from Github into plugin folder of the Cura? I just did that, restarted the program and din't get the message as you showed.
There are several ways that plugins can be installed. The easiest is to install it from the Cura marketplace dialog.
8 hours ago, burtoogle said:There are several ways that plugins can be installed. The easiest is to install it from the Cura marketplace dialog.
Thanks! I have figured out how to install the plugin and yes it says that the model is not watertight. I have used one of the open instruments to fix my model automatically and it did fix it. But still, I don't know what I did wrong in the first place, because I have looked everywhere and didn't find where it is broken.
burtoogle 506
It's probably because the model isn't watertight. Install the mesh tools plugin from the marketplace to get these warnings...
