This information helped me a lot, thank you!
I have one more question about this.
Is it also possible to see in cura --> Before which movement a Z Hop was executed?
Because of the Option to select „Z Hop Only Over Printed Parts“ in Cura it is not realy clear to me which movement with retraction is also with an Z Hop.
Edited by grs
ungutknut 3
If you go to layer view, select the line type color scheme and enable travel lines, you can see where retraction happens. Dark blue lines are unretracted, light blue is retracted.
mariocoppola 1
thank you SOOOOOOOOO much!!! :-))))))))
thorsenrune 11
Could I suggest to add this information to the tooltip over the colorscheme so everyone knows
