HI SandervG,
Well, the page is all different, so I'm not sure if it still exists anywhere, but I expected to find the information I was looking for at this link: https://support.ultimaker.com/hc/en-us/articles/360011490220-Check-for-play-on-the-axles-of-the-Ultimaker-3
Which is when I usually check the play on my axles. The prior documentation had this whole list of loosen all the set screws, then tighten them in a certain order, and then line up the print head using calibration sticks which it also had a link to download the STL, and then continue on. It was pretty in depth, and particularly I think the order is important in regards to getting the slider blocks aligned if they happen to be misaligned (I happened to just change my belts, so I definitely had to get that right).
Anyway, the new page just starts with one axle and then says 'and then just repeat for the other axles and if you're having trouble do a print head calibration print'.
Anyway, not sure about the rest of the maintenance docs, but that was one I happen to reference pretty regularly when I woudl do my regular maintenance.
Also, I forgot to mention that I run an Ultimaker 3.
Thanks!
Bobby
Edited by bsaygan
SandervG 1,518
Hi Bobby,
thank you for your message. It is possible that documents have been moved when we made some changes to the website. Last year we also rebranded some elements from our site and brand, which may have led to updating the actual content of the documents. This should mean they have gotten better, not less detailed.
Could you share which documents you are looking for, or for which printer? Perhaps I can help locate them for you.
Thanks,
