fbrc8-erin 267
It might just be a heat sink issues, but it's also possible hardware damage, so you're definitely safer using an external heat source. Good luck!
fbrc8-erin 267
Do you have a heat gun or soldering iron you can apply to the plastic?
At best, all the filament around your printhead is acting as a heat sink and and causing the error; at worst your heater and/or temperature sensor may be damaged (I'm not familiar with the Tevo) and the error is there to make sure you don't have thermal runaway.
Best bet is to apply an external heat source and pull material away with pliers or similar.
paulrhee2002 2
So the heat sink thing is probably wishful thinking on my part?
Hopefully it's fixable and will get a soldering iron.
I'm fairly new to 3d printing so today I learned heat sink and soldering iron.
Thanks so much Erin!
