granted .
tried the .1 change still has it
the adaptive layer is enabled which does help to some extent
at the top i do have it with different infill which is needed being it has a threaded part on the underside so that needs the strength
notably i know there will be some post processing the less on the the better for the smoothing part
currently the part takes 2 hours to print
.1 takes around 2hr30 give or take which is do able perhaps im missing something here
side note would bumping nozzle to 245 add any help for this?
amazon abs
hopefully no one throws anything at me for being little hardheaded here 😉
(attached some of my current settings for viewing pleasure )
Edited by fellfromheaven
gr5 2,210
If you change the layer height from 0.2 to 0.1 there will be twice as many circles and so harder to see. Each step will be half as thick so *also* harder to see. Unfortunately it will also take twice as long to print.
Also you can look into "adaptive layer height" which is a feature in Cura where you can set the minimum and maximum layer height and it will switch to thinner layers at the top of your rounded-top part.
