How to partially infill
Bah454
Posted · How to partially infill
Hello-
I am trying to print this part with a hole that goes through 1/3 of the way. I have tried many different approach S like zeroing the infil and going to special mode and changing it to surface mode, but it still prints a infil or support in the hole. The part is printed in the same position as in the pic with pink lines.  Any help or advice would be greatly appreciated.
Brad
    Hi, thanks for the model. Well, I sliced it using my normal settings and it looks OK, here's the last layer of the hole...
    Here's the same model with the remove all holes setting enabled, perhaps you have done that?
    Hello Burtoogle, Happy 4th  of July!
    Wonder if you can offer me some more advice.
    I keep getting an error when I downloaded Cura 4.6.1 pic included. That is causing some issues I think with printing.
    Issue-
    I must print my part using the standard Brim. However when I do that the part wont stick to the plate. I've printed many of these and never had this issue. This is a brand new printer, same model I used b-4 Monoprice V2 mini with no Brim Issues. I looks like to me that there isn't enough filament coming out on Brim mode. Is this adjustable, does it need to be adjusted. It shows 100%
    But, when I switch to Raft it sticks no problem. Raft is not a strong enough hold for this part. I really need to fugue out what is causing this. Is it the error I keep getting when I down load Cura, Is it a setting that I am missing?
    Any help is appreciated.
    MSMV2E3D_rev11 (3).3mf
    Remove those profiles and see what happens...
    Issue-
    I would personally reset Cura so it's all back to default settings, if you still get a problem with brims not sticking it could be that the print cores/feeders need to be cleaned.
    Because you might not be getting the full filament flow, what means the filament don't get pushed down to the glass as much.
