A PROBLEM IN THE FITTING ON THE SCREEN
ubuntuman
Posted (edited) · A PROBLEM IN THE FITTING ON THE SCREEN
Hi Guys
i Cura 4.6.1 i try to go down wards as u can see in the picture
In the per model setting to modify my added settings in the list but i cant
Because simply they are dow and i cant select them . there is no scroll down !!
so any one has a suggestion for no-existing scroll down ?
Edited by ubuntuman
    Posted · A PROBLEM IN THE FITTING ON THE SCREEN
    Using the PI 4 build, I get the following behaviour...
    If I add enough per-model settings, I get a scroll bar to access them. Like this...
    But if I make the Cura window less tall, I can no longer access the bottom of that dialog...
    Can you make the Cura window taller?
    what is the PI 4 build?
    Just now, burtoogle said:
    Thank you
    but i use ubuntu and cura 4.6.1
    and in the second picture in my second reply above ,i make cura window to be full screen but still not working
    I still dont have scroll down
    1 hour ago, ubuntuman said:
    by the way i use ubuntu as operating system , so this is linux distribution of cura 4.6.1
    Have a look
    I think this is a fundamental limitation which is a consequence of how they have implemented the UI. I can't think of a workaround. Sorry.
    I have a workaround which I will describe how to do later but in the meantime, here's a picture to show what I did...
    Here's what you do...
    1 - extract the contents of your AppImage file by specifying the --appimage-extract option. This extracts into squashfs-root.
    2 - download and unzip the attached Toolbar.zip.
    3 - copy the replacement Toolbar.qml to squashfs-root/usr/bin/resources/qml/Toolbar.qml
    4 - run the patched Cura by executing squashfs-root/AppRun
    Hope this helps.
    Toolbar.zip
    Hi @ahoeben, you're a QML wizard. Can you suggest a means whereby the anchor position for that tool panel can be changed based on the position of the tool button selected? I'm thinking it would be nice if the top 3 tools (Move, Scale & Rotate) anchored the panel at the top (like it currently does) and then the following tools (per-model settings and anything else that comes later) could anchor at the bottom of their panel like I have done in my modded Toolbar.qml. I tried using conditional expressions but couldn't make it work. Any ideas?
    Hope this helps.
    how to extract the AppImage?
    By adding the --appimage-extract option to the command line after the appimage name.
    and how to delete the extrated files in case i want to delete them?
    It works
    Thank you
    and how to delete the extracted files in case i want to delete them?
    Edited by ubuntuman
    and is there a way to report ultimaker team  about this bug ?
    You're kidding, aren't you?
    Sure, but don't worry, I will follow this up with UM.
    Hello, I have the same problem with Cura 3.3.1 on mx linux not showing the lower part of the screen on my laptop with resolution of 1366 x 768.   I have not attempting the mentioned solution above.  I don't normally use Cura on my laptop but it would be helpful for it to adapt to the laptop resolution.
        • 27 replies
