Hi Nitro2k01.
As I explained, I've already looked at the Material profile for Generic PLA and in that the Default Build Plate Temperature is 50 degrees. There's no setting for temperature in the Printer profile and in the overall Profile the Build Plate Temperature and the Build Plate Initial Temperature both show 50.
I know I can override it in the Profile, but what I want to know is where the initial value of 60 comes from which has been put into every GCode file I've sliced for the last 6 months. Until today, I'd never changed any temperature setting in CURA so why has it been outputiing 60 and not 50.
Where does the value 60 come from?
nitro2k01 2
These are set in two places.
1) These settings originally come from the material profiles. In the top of the screen, there's a menu bar with three sections. Click the middle section to reveal a window with a selection of material and nozzle size. Click the material and select a profile or click manage materials. Here you can create material profiles with custom settings.
2) However, if you are experimenting in day to day use, it's probably more common to use a temperature setting override. Click the right part of the same menu bar. This reveals a window with settings for the layer height, infill, support and adhesion. In the bottom, click custom, and you will see a long list of settings you can change to override the profile, including bed and nozzle temperature.
