GregValiant 1,318
The geometry of a part is part of your problem. Cura knows it missed spots and goes back and fills them. You can see them in the preview view. They will be little areas of yellow infill amidst all the red and green wall lines. The more sides a piece has the less noticeable the problem is. When you have only three sides and your nozzle is round, it can't get tight into the corners and the software knows that. For structural soundness, filling those gaps is the thing to do.
There are settings that will cause it as well. I know Combing will run the head all over as it tries to avoid printed areas.
I haven't used Fill Gaps Between Walls but it sounds like the kind of thing that will cause a lot of running around also. Hopefully a moderator will chip in with some ideas for you.
PCLoadPLA 0
I found the solution...set "fill gaps between walls" to "nowhere" or else use the Filter Out Tiny Gaps option to remove the little tiny extrusions. My print time decreased by nearly 20%, with almost no change in plastic used.
