Dim3nsioneer 559
Did you perform a factory reset after the firmware update? This is what I would try first. It might be a variable not properly set up needing re-initialization.
I did a factory reset after I reverted it back to 5.5.12 but the X- axis keeps coming back misaligned. I am truly stumped by this one. Not sure why the x- axis coordinates would be misaligned after installing the 5.7.2 install.
Edited by ccmaker2020Can you show us pictures of how exactly misaligned the print is coming out?
If the XY calibration is successful, then maybe theres some Cura print settings that can be improved? If you have spare print cores also lying around, it could be trying to use them to see if theres a difference in behaviour.
ccmaker2020 2
I fixed my camera issue and alignment. I had to revert back to the old firmware and go under printer settings as I noticed my 2nd extruder was misaligned by a couple of mm off.
