Ah! Got it.
You have many options. Your print probably doesn't need any support at all so you can probably just turn it off.
However, to answer your question - you can use "support blocker". First click on your part so it is selected (don't know why this is necessary). On the left side of cura, there are a bunch of icons. The bottom one, "support blocker", (maybe 3rd from bottom) - click that, then click at that base of your part. It will create a cube there. Then while that is selected, use the other tools on the left side to move and scale your cube. You can uncheck the "lock" checkbox in scale mode if you want to scale the vertical differently from the x/y dimensions.
Then do a slice and see how well that works. You might want to set "support horizontal expansion" to a small value or even to zero.
1
There are videos to show how to do this - google "cura support blocker".
2
bradh733 1
Thank you for your response.
here are a few screen shots to help you get an idea of what I’m trying to accomplish.
I’m working on getting the file saved as you suggested so you can see my settings.
