Hello gr5
Thanks for your reply.
My printer is only a few months old. Would it perhaps help updating the firmware? I haven't done this at all.
I can't see any missing layers in Cura (https://imgur.com/a/ho4czXE).
Hello gr5
.... should print out of the box, no firmware update needed...
Check printer if it is assembled the right way, they sometimes make mistakes in China!
What layerheight did you use?
Edited by Mari
gr5 2,210
This is unrelated but just as important - see how some of the exterior walls of your model are white and some are gray? They need to be all white or cura does unpredictable things. So right click all the gray walls in sketchup and choose "reverse faces".
But to your issue - I'm not certain what the problem is. In Cura, make sure to look at your print in PREVIEW mode and scroll through the layers paying most attention to the last (top) layer. I'm wondering if maybe your printer stopped printing early - there was a problem with Marlin (firmware) on the UM2 a while back where it wouldn't print the last few lines of gcode. It seems unlikely that your printer has the same problem but still.
Or maybe you have a lot of backlash in your printer (e.g. the belts are loose). Or maybe you are underextruding but I don't notice underextrusion anywhere else.
